Steve's CH750 Cruzer (N750SB)
Date:  12-18-2018
Number of Hours:  1.50
Brief Description:  Added inspection plugs, clearance trim
To plug the inspection holes in the horizontal stab, I put in place some plugs I had made earlier. I purposefully made the holes to fit grommets. To make the plugs, I filled the center of the grommets with Flex-Seal liquid rubber and let dry. Then I wrapped string into the groove to prevent it from filling and dipped the center-filled grommet in white Flex-Seal and let dry. The result fit very snug into the hole and will not get blown off, yet can be worked out when the hstab mounts need their annual condition inspection.
Performed some additional trimming on the fin lower skin to prevent the edge of the fin skin from abading on the hstab skin.
Inspection plug
Inspection plug
