Brief Description: Adjusted main gear axle tension and cotter pinned
Adjusted the friction on the main gear bearings per Matco instructions. To raise the wheel I used a square tube as a lever and wood as the fulcrum. The solid bottom of the gear leg is where the lever goes so it doesn't interfere with anything. When done, I added cotter pins to the axles.
