Brief Description: Installed new fuel sender and clips
I replaced the passenger side fuel sender that was sticky. Since there is unusable fuel in the tank, I grounded the plane before removing the sender. I reused the bent float arm and installed the new sender. Finally, I recalibrated the new empty setting on the gauge.
I added some zip tie clips to route the sender wires.
