Steve's CH750 Cruzer (N750SB)
Date:  12-31-2018
Number of Hours:  0.25
Brief Description:  Pilot side fairing edge prep
Taped clear saran wrap to the wing root area on pilot side. Taped fairing into position on pilot side. Used some white Flex-seal glue to taper leading edge of fairing into wing area. Letting it cure before removing. The saran wrap should keep it from sticking to the wing. Hopefully I will get something that can be trimmed nicely.
Curing the leading edge pilot side
