Steve's CH750 Cruzer (N750SB)
Date:  11-17-2018
Number of Hours:  5.00
Brief Description:  Finished header tank access panels
Used the templates to drill nutplate rivet holes. Then I used the nibbler to rough out the openings in the baggage back skin. Ground, filed, and sanded to smooth out the rough edges. Dimpled the rivet holes and nutplates and installed the nutplates. This should improve access to the header tank plumbing.
Pilot side access panel
