Steve's CH750 Cruzer (N750SB)
Date:  11-16-2018
Number of Hours:  2.25
Brief Description:  Started work on header tank access coverings
I felt that I needed better access to the plumbing near the header tanks than is provided thru the hell hole. I had earlier fabricated some extra access covers for this eventuality, so I marked and drilled the nutplate holes.
I should have thought of this a lot earlier, but I cut the opening size in one of the covers and added nutplate ear holes for positioning the A3 rivets. Using this template, I can quickly lay out the pattern for any additional access openings I may need. This made things a lot easier as it took some contortions to work on the baggage back without damaging the lower floor structure which doesn't yet have the panels in place.
Access marked and nutplate holes drilled
Cover template
Cover template
