Brief Description: HS Fix - Fit new skin, drill additional holes
Fitted the new skin, added piano hinge extensions to the elevator. The new skin fit well. I drilled the additional holes for the ribs as required for the fix. Expanded the holes to A5 size for the hinge extensions. Fitted and cleco'd everything together.
The new skin, hinge extensions, and rivets from Zenith
