Steve's CH750 Cruzer (N750SB)
CH750 Cruzer
Installed transponder GPS antenna
Installed the antenna for the transponder GPS source. It came with a template, so I put it on the pilot side roof and drilled the holes. Attached clips and routed the cable down the column into the baggage floor.
Transponder GPS antenna mounted
CH750 Cruzer Home
2029
Avionics/Electrical
Cabin
74
220
Doors/Windows
Elevator
225
Firewall
Flaperons
Horizontal Stabilize
Shop Prep
Travel
Vertical Fin
Wing - Port
92
332
332
