Extended the piano hinges with more segments towards the front. Could not get the pin to make the corner though. Still, the hinge adds rigidity and I might be able to get a smaller hinge pin to try. In any event, it makes positioning the top cowl easier. I have them attached with clecos for now. Also did some fiberglass work to cover up some thin spots and start to build up a surface I can sand to a smooth surface. Ran out of Bondo in the process. Nothing exciting to look at, so no pictures this time.
