Steve's CH750 Cruzer (N750SB)
Date: 5-25-2018
Number of Hours: 2.50
Brief Description: Mounted prop, hub, and spacer
Temporarily assembled the spacer, spinner back plate, hub, blades, and spiner to the engine. I know it will mostly be coming off again to fit the cowling, but I needed a break from wiring and wanted to see how it would all fit. I didn't even remove the protective packing material from the blades or make an attempt to set pitch. I will need to remove the blades for cowling fitting, but will need the spacer, spinner backplate and hub to position the bottom cowling. Everything seemed to fit together well.
Prop, hub, spacer, spinner
Prop attached
