Steve's CH750 Cruzer (N750SB)
Date:  5-24-2018
Number of Hours:  3.50
Brief Description:  Tweaked control rigging
Taking care of a few items that needed attention. Made some adjustments to the flapperon controls. Turns out I was able to get better control deflections and neutral position by swapping out my modified belcrank on the passenger side with the original and leaving the new version on the pilot side and adjusting the rod ends on each.
Also adjusted the stick rod end to move the stick forward. Nevertheless, I did have to add a curve to the forward tunnel cover to prevent the stick from contacting it in the full back position.
