Continued the wiring process. Adding labels to wires and continuing to from looms to keep things organized. Started organizing the rats nest behind the center console. All the wiring needs to be kept clear of the cables that run in that area. This entry and the next 2 will cover the work done over the weekend in aggregate. I went back and forth to different areas, so a linear log would be kind of disjointed.
