Steve's CH750 Cruzer (N750SB)
Date:  3-11-2018
Number of Hours:  8.75
Brief Description:  More wing tip work
Yesterday and today I finished up the pilot side wingtip and lights. I had ordered a bundle of computer cable 4 wire paired connectors and suded one to join the cable and the light. Also used some wire loom and tie clips to provide strain relief.
Moving on to the passenger side, I drilled out the rivets and removed the cracked wingtip pieces and began fitting the new ones. Got them positioned and drilled. Removed the clecos for clean-up and light installation, but ran out of time.
Spring break is next week, so hopefully I'll be making more progress then.
Pilot side wingtip and lights installed
Passenger side wingtip positioned and drilled
