Brief Description: Continued passenger side fuel routing
Completed drilling, deburring, and grommeting the openings for the wing to header tank routing on the passenger side. In the photo I have inserted a short length of fuel line. It is a snug fit, but a little bit of silicone grease on the grommet lets the line slide through without any problems. Reattached the passenger side wing. I'm starting to get this wing fitting/removal process down pat. I kind of like that the grommets provide a bit of protective cushion for the side skin against trailing edge scrapes while fitting the wing.
