Steve's CH750 Cruzer (N750SB)
Date:  1-10-2018
Number of Hours:  2.50
Brief Description:  Starting fuel line routing from wing
Started working on routing fuel from the wings to the header tanks. Starting on the pilot side, I marked where I would need to drill my grommet holes. There is not a lot of room in the trailing edge profile to work with. I'm using 1/2" fuel line which means 1" holes for the rubber grommets. The fuselage side channel takes up a lot and I didn't want to drill through that at this location. Eventually I found some sites. Now just need to figure out where to put pitot/static and wires.
Pilot side fuel/vent passthroughs
