Steve's CH750 Cruzer (N750SB)
Date:  11-5-2017
Brief Description:  Fabricated platform for fuel components
Temporarily removed both header tanks for elbow room. The mounts were still just cleco'd, so no big deal.
Deciding how to mount the check valve assembly and fuel filter, it seemed obvious that I would need some sort of platform or brackets since nothing can sit directly on the bottom skin. So I fabricated a platform on the aft pilot side of the hatch to hold those components. I will have the headers teed into the check valve assembly and then a line going to the filter. Not sure the pressure sensor wiring will reach back that far, but I have a standalone inline sensor adapter I can use anywhere forward.
Platform for mounting check valve and filter
