Steve's CH750 Cruzer (N750SB)
Date:  10-29-2017
Number of Hours:  2.75
Brief Description:  Door frame reinforcing brackets
Worked on the inner frame reinforcement brackets. Positioned, drilled and cleco'd in place. Once all were drilled out to final size, I removed them from the frame for debur and treatment. Installed and riveted until my supply of AS5 rivets ran out. I had some elevator/stab rework a while back and I guess used too many on that. Will order more from Zenith.
Bracket riveted with AS5
