Did some rough fuel line routing. From the engine, I routed the line along the radiator and drilled an entry hole in the channel area just forward of the gear. The pilot side had the best clearance for control travel, so I used that side. Then back to the header tank area, drilling another hole for passage. I need to get some additional injection hose to connect the header tanks. I will need to get some additional fittings before securing everything.
