Steve's CH750 Cruzer (N750SB)
Date:  9-19-2017
Number of Hours:  0.75
Brief Description:  Started install of new flywheel part
Started to work on the replacement of the flywheel bracket with an updated part provided by Viking. The gearbox came off with no problem, just remove the 4 mounting bolts. Where I ran into issues was getting the 6 star bolts off. Per the suggestion provided in the YouTube video for the process, I ground down the front of a 17mm socket to try and get a bite on the low heads, but no joy. That just stripped the socket. I guess this is a good excuse to go buy more tools, specifically a 1/2" impact wrench, sockets, and an adapter since I will need to use my 3/8" torque wrench to reinstall.
Also confirmed I have the flywheel welds which are not on some flywheels, and would have necessitated the flywheel being welded or replaced.
Gearbox off
Gearbox off
