Steve's CH750 Cruzer (N750SB)
Date:  8-19-2017
Number of Hours:  5.25
Brief Description:  Continuing engine hookup
Got a partial shipment from Del City yesterday containing blade connectors, so I started making up the ends of the wires that connect to switches. I also placed the ignition switch on the center console. Ran gray stripe spilt loom up the length of the throttle cable. In addition to protecting from abraision, it will help prevent any accidental shorts as the cable has to have some play behind the panel to accommodate the fold-down feature. Also added the gear temp sensor and the oil pressure sensor. The fuel pressure sensor will have to wait until I run the fuel lines. Decided to hold off the coolant temp sensor until the flywheel bracket fix comes from Viking as I expect the gearbox will need to be removed and it will be easier to access the install point then. Also started connecting wires for the Viking View display and sensor unit. I may end up moving the ECU and sensor unit off of the top of the avionics shelf. Thinking of mounting the ECU on the bottom of the shelf or on the interior of the firewall. May put the sensor unit on the side of the center console so the light is visible.
Making up switch wires
Gear temp sensor
Gear temp sensor
Oil pressure sensor
Oil pressure sensor
