Lots of different stuff done today. Started cutting lengths of wire for the engine related items, but have not yet added terminals. Mounted engine switches and breakers on center console panel. Mounted throttle in panel where it felt right to reach. Put the actuator end of throttle cable into its clip, but did not attach the end yet. I may end up adding a backing plate for the panel throttle mount area. I have various terminal connections and split loom on order
