Cut the firewall wire passthrough hole. Decided to put it around midway up above the shelf where it would be convenient to have the motor mount provide support. Getting the engine plug connectors through was a bit interesting. Had to remove the wires from a portion of the loom so they would lie flat against the plug in order to get the ECU plugs to fit through. After that, everything went through easily. Put the passthrough fitting in place, but did not attatch at this time.
Also trimmed the plywood avionics shelf a bit for a better fit. The ECU plugs reach the computer just fine with the current layout.
