To get an idea where the pulleys need to go I ran string from the elevator attach points to the bellcrank. Assembled a pulley and tried different locations. For the lower elevator control there was lots of play to locate a pulley. The upper really doesn't have a good location where the string/wire won't rub either the elevator skin or lightening hole. I suspect I will need to open up the lightening hole a bit. Will see if others have had this issue when CenturyLink fixes the DSL connection to this area.
