Steve's CH750 Cruzer (N750SB)
Date:  6-17-2017
Number of Hours:  1.25
Brief Description:  Elevator balancing
Raised the tail to normal height. Started adding weights to horn. 6 large and 1 small counterweight was too little and adding another small was too much. Started removing material from the 2nd small counterweight. Used a cut-off wheel to remove large chunks and a grinder to fine-tune until the elevator would hold a neutral position for a second or two. Torqued the nuts on the bolts holding the counterweights.
Material removed from final weight
Counterweights attached
