Steve's CH750 Cruzer (N750SB)
Date: 4-12-2017
Number of Hours: 3.25
Brief Description: Stiffeners debur, treat, rivet, reassemble, start
Took apart stiffener assemblies, deburred, treated, and riveted the Ls and covers together. Removed the firewall and heel gussets. Deburred, treated. Deburred new holes on forward skin. Treated firewall, gussets, and forward skin where necessary. Only riveted the heel gusset to the heel plate. Reassembled, but did not rivet as I think I may need to be able to do further deburr once the top skin is positioned and drilled.
Started working on the motor mounts. Made small knotches in the top mounts to accommodate firewall skin folds. Drilled the front hole for the bottom mounts to assist with positioning and cleco'd in place.
Stiffener assemblies riveted together and positioned on forward skin
Starting to attachmotor mounts
