Final installation of the pedal assembly. I had taken it out when joining the fuselage. Installed and torqued the bolts on the end and center bearings. Added some grease to the bearing surfaces. Attached the brake cylinders, but did not install the cotter pin on top since they will need to be adjusted later.
