Steve's CH750 Cruzer (N750SB)
Date:  3-18-2017
Number of Hours:  5.00
Brief Description:  Drill Longerons, Brake pedals
Pilot drilled front longerons. Marked brake hinges and bent into curved shape on bench vise. Used a hammer and block of wood to make the curve. Drilled the holes in the brake pedal and tube and upsized to #20. Deburred and corrosion protected. Riveted using the stainless steel rivets.
Repositioned the fuselage to get a better angle and lower the assembly for fuselage joining later.
Brake pedal rear
Brake pedal rear
Brake pedal front
Brake pedal front
