Started trimming the ends of the cabin frame, starting with the top. The pre-drilled hole is supposed to line up with the 1st hole in the top gusset. This puts it very close to the end. Used masking tape to delimit the cut line and used a dremel and hacksaw to make the cuts. Only got to do the tops today.
