Steve's CH750 Cruzer (N750SB)
Date:  1-27-2017
Brief Description:  Torque tube mounting, baggage bottom reassembly
Now that the parts are prepped, I started the reassembly process. Cleaned the powder coat off the ends pf the torque tube with the scotchbrite wheel. Added nuts to the bolts holding the torque tube bearing onto the brackets. Inserted torque tube ends into the bearings and cleco'd the assembly into place. Added the L angles to each bracket. When assembling, applied grease to the moving surfaces. Movement is stiff, but smooth, no binding.
Cleco'd the flapperon channels back in place then the baggage seat.
Starboard torque tube bearing area
Port torque tube bearing area
