Brief Description: Retrieved steel parts for powder coating
Found all the steel parts to be powder coated in all my different boxes and the ones I had left in the Zenith "Steel Parts" box. In the process I came across a little packet marked "wings" that I had overlooked. It contained A6 rivets and zipties. In building the wings I used the A6 rivets from the airframe box and my own zipties. Took a while to figure out how to fit the fuselage frame into the cab of my pickup, but got it done (rain forecast for the next several days). Almost forgot the box with the flaperon counterweights. I decided to go with the Viking steel bungee, so included the steel spring and left out the original bungee pin. It may be overkill, but I picked up anything that was a fixed steel part (not stuff like cables). I'll probably drop it off in a couple of days.
