Steve's CH750 Cruzer (N750SB)
Date:  11-25-2016
Brief Description:  Skytek fuel line install
Deburred the front spar and skins where not already done after drilling was done a while ago. Installed the Skytek fuel line package. I purchased it and the Skytek header tank after seeing the installation in a Cruzer at Open Hangar Days. The installation instructions on the website are a bit disjointed, but once the hole for the return line is drilled, the rest is pretty intuitive. Used Loctite 567 on the AN fittrings. I will do another leak test before buttoning up the top.
Fuel return
Fuel return
Fuel Outlet
Fuel Outlet
