Brief Description: Final wingtip fitting. Attached AeroLED to wingtip
Final fitting of wingtip pieces to wing. Drilled all holes to final size. I think the fit is pretty good. Removed wingtips and did final debur. Attached AeroLED to wingtip using the backplate I fabricated, which also serves as a template. The printed instructions that came with my kit had a printed template which was too big. Used blue threadlocker on the 6-32 bolts and nuts I picked up at Home Depot. Seems there is some controversy in the forums about grounding technique for these things. Decided to start out with grounding per manufacturer's instructions. So I will have local grounds for AeroLED black wire, mounting screw, and cable shield.
