Steve's CH750 Cruzer (N750SB)
Date:  11-19-2016
Number of Hours:  3.00
Brief Description:  Wingtip Work
More fitting of the wingtip. Got a good fit of the front by pushing down on front part with wing in the cradle and marking top and bottom front holes while under pressure. Drilled those holes and used a couple of wingnut clecos to pull the plastic in tight. Used copper pipe with #30 holes for the wingnut clecos to pull the skin from the inside. Drilled and cleco'd the remaining holes on the front flange to get a good fit. Was ready to mount the wingtip strobe, but discovered the kit did not include screws to mount the attachment plate on the wingtip. In any event, the thin plastic would need something else to secure the holes, so fabricated a couple of backplates from junked wing root skin. Just need something more secure than plastic to attach the mounting screws to when I get them.
Wingnut Clecos from Inside
Wingnut Cleco's.
Wingnut Cleco's.
