Finished riveting the bottom skin. I will wait to rivet the pitot/static tube until just before sealing up the top skins so I don't have it sticking out any longer than necessary while I am manipulating the wing. Inserted AN7 bolt into upper strut bracket and fitting to determine location for the A5 rivet that attaches the fitting and doubler. As I mentioned on the left wing, I believe the only purpose of this rivet is to help restrict sliding of the fitting and doubler when the bracket is attached to the fitting under load.
