Steve's CH750 Cruzer (N750SB)
CH750 Cruzer
More wing skeleton work.
Removed rib and drilled fuel return hole. Figured it would be easier to do this now using fly cutter. Cleco'd spar tip and expanded 8 holes for A6 rivets. Drilled L angle for spar tip and positioned. Drilled and positioned 1 flaperon bracket.
Fuel Return Hole Drilled
Ribs cleco'd to main spar
CH750 Cruzer Home
2029
Avionics/Electrical
Cabin
74
220
Doors/Windows
Elevator
225
Firewall
Flaperons
Horizontal Stabilize
Shop Prep
Travel
Vertical Fin
Wing - Port
92
332
332
