Steve's CH750 Cruzer (N750SB)
Date:  9-11-2016
Brief Description:  Drilled root mounting hole, riveted flaperon arms.
I should have done this on the drill press before assembling the skeleton, but drilled the wing attach hole to 3/8 with step bit and electric drill. This would be even more difficult if I waited until the skins were riveted. Cortec applied and riveted the flaperon arms. Applied cortec on mating surfaces of top skin and ribs. Still working on getting nose root skin to fit better.
Wing attach hole
Wing attach hole
Flaperon arms attached
