Steve's CH750 Cruzer (N750SB)
Date:  8-31-2016
Number of Hours:  5.50
Brief Description:  Drilled top skin, Attached root rib.
Finished folding leading edge skins. Positioned top skins. Drilled main spar nose and top skin holes to size 20. Drilled the frontmost top and bottom leading edge holes that I held off on untill skins were fully folded. Sure wish Zenith had included more black cleco's in the tools package. I ended up moving them off ribs and rear spar as I drilled the main spar. Edge finished and deburred the root rib parts. Upsized the holes in the spar to accommodate the A6 rivets that sandwich the spar between the rib ends. Cortec applied and riveted root rib parts to spar and bottom skin, keeping the rear spar and inboard edge holes open for additional skins.
Nose and top skins positioned for drilling into spar.
Moved clecos onto spar as drilling progressed.
Root ribs in place.
Root ribs in place.
