Brief Description: Tested servo, responded to Roger
Tested the trim tab servo with 9 volt battery. The actuator extended and retracted as expected.
Roger responded to my email on the elevator skin alignment suggesting I use a wider hinge, but that doesn't fix the misalgnment of the lip, which puts the holes in the lip too close to the lip edge. I sent more photos clarifying the problem.
