Brief Description: Servo fitting, disassemble for deburr and Cortec
Attached the servo arm to servo and attached to trim tab. Actuator is fully closed, so had to loosen turnbuckle some more. Cleco'd servo in place and added L-Angle. At this point the Zenith assembly guide essentially jumps ahead to a fully painted stab/elevator assembly. Thank goodness for the HomebuiltHELP DVD. Disassembled everything for deburr and corrosion protection. Deburring and applying Cortec is where I left off for the day. More of both tomorrow along with reassembly and riveting (hopefully).
