Riveted rib extensions. Fitted end caps, drilled and cleco'd. The end caps and piano hinge are to remain unriveted at this point. During assembly, made sure the rib extension was perpendicular to the rear spar before drilling. When I get my replacement attachment bracket, I will trim and rivet that in. Set the stab aside and cleaned up the work area in preparation for elevator assembly.
