Steve's CH750 Cruzer (N750SB)
Date:  7-6-2016
Number of Hours:  5.00
Brief Description:  Deburred, Replaced Rivets, Riveted top skin
Deburred piano hinge, rear spar, doublers, and skin. Performed one last inspection inside before riveting top skin. Found a few rivets that were not quite right, so drilled them out and replaced them. Ended up fabricating a new L angle. Riveted the doublers to back spar with A5 rivets. That took longer than expected. No room for the pneumatic riveter, and it was tight for the manual one. Did not rivet the rear spar attach bracket since I have a new one ordered after I messed up the trimming on the original. The piano hinge apparently gets removed later, so just cleco'd that edge. Top skin riveted to the front spar and ribs with A4 rivets.
Piano hinge doesn't get riveted now
Starting to look kind of airplane-ish
