Steve's CH750 Cruzer (N750SB)
Date: 5-26-2016
Number of Hours: 1.00
Brief Description: Repositioned items to make room, replaced floresce
One area of the shop building is partially enclosed with storage on top. I figure that until the build gets too big, this is a good spot to work as it already has lighting, outlets, and a bench in back. Also, come winter, I can close off the front and use a space heater to make it more comfortable. Once the wings are ready to go on, I will take the truck out, rearrange some more, and should have enough room to assemble the big parts. Today I had some minor surgery in the morning, so I took it easy and just moved some stuff out of the way and replaced the florescent tubes.
