Began getting things together in the center stack so I can drill mounting holes for the GTR200 Radio. The GMC 307 Auto Pliot Controller only needs the faceplate to attach. Shallow and light part. The radio stack will get attached to the front angles and integrated into the modified support ribs. My avionics will be very robust for a VFR platform. I've designed this to accomodate IFR equipment in the center stack for later....if needed.
