I'm using a series of aftermarket, upgrade parts. The tailwheel yoke from JD Air has bearings and is better built than stock. It is almost match drilled to the existing tail stinger. This was quite difficult to get aligned and the two bolts inserted. Finally got it and torqued the nuts.
