More reinforcements to fabricate. The center one is simple, as it only needs fluted to follow the contour. The other two are notched like the panel reinforcement, but this is thinner material and a bit easier to work. Lots of measuring, drilling, cutting, filing, deburring, the attaching. These angles are installed an eighth of an inch lower than the panel tops to allow an area for weatherstripping to be installed.
