I did it! The BIG CUT. All the nerves were spiked and I decided I prepped as muc has possible. It's time. I got the die grinder wound up and began making a score line between the tape lines. I eventually made cuts at the apex, middle, and then connected all the cuts. Once I got the pieces cut in two, I carefully got some space between the cut lines. I began with 80, then finished with 220 grit paper to dress the edges and prevent cracks. This was about the time I finally took another breath. Time for a beer!
