Worked on locating the ribs and angles, so they will properly capture the radio stack and integrate to each other. I've made the accomodations to have this modular, so I can remove the panel and its components later as needed. A lot of head scratching and a little actual work to this point. Using the Aerosport Panel will be great, but it's not as obvious how to address some of these areas.
Get it straight!
Checking location of holes in faceplate.
Ribs relocated and match drilled to panel frame and angles.
