"Here goes. I decided to start construction of the vertical stabilizer. This is probably the simplest assembly within the Empennage Kit, so a good way to get my skills honed again.
Deburring is a necessary, but tedious must in this process. I got all the skeleton deburred and adjoining parts match drilled.
Still deciding which primer I'll use this time. Probably rattle can and more than likely Napa 7220 Self-Etching Primer. Many other builders report good performance."
