Sean's RV 7 Project
Date:  7-8-2017
Number of Hours:  2.30
Brief Description:  Static Ports
Located and drilled holes for the static ports on each side of the tailcone. I had to make a slight adjustment forward of the Van's depiction, so I wouldn't interfere with the underlying bulkhead flange. This is also due to the fact I'm using SafeAir ports and they occupy a larger footprint than Van's blind rivet approach. I bonded with ProSeal and used magnets on both sides of the part to hold it until cured. No rivets this time, as ProSeal should hold these just fine.
Step drilled to size.
Magnets hold the part in place.
Interior view.  Will touch up primer later.
