Sean's RV 7 Project
Date:  6-6-2015
Number of Hours:  1.80
Brief Description:  Tail Gear
I'm using a series of aftermarket, upgrade parts. The tailwheel yoke from JD Air has bearings and is better built than stock. It is almost match drilled to the existing tail stinger. This was quite difficult to get aligned and the two bolts inserted. Finally got it and torqued the nuts.
JD Air Yoke.
JD Air Yoke.
Finally got the hardware installed.
Torque sealed.
Torque sealed.
